Fatal error when module enabled
More
8 years 5 months ago #874 by philg
Error message on the frontend when I enable the module:
Fatal error: require_once(): Failed opening required '/home/glassbyc/public_html/modules/mod_verticalscroll_jt1/k2helper.php' (include_path='/home/glassbyc/public_html/plugins/system/shlib/shl_packages//ZendFramework-1.11.7-minimal/library:.:/usr/local/php70/pear') in /home/glassbyc/public_html/modules/mod_verticalscroll_jt1/mod_verticalscroll_jt1.php on line 14
Also, in backend, when I go to the tab SOURCE SETTINGS, I get this error:
Warning: htmlspecialchars() expects parameter 1 to be string, array given in /home/glassbyc/public_html/libraries/joomla/form/fields/text.php on line 217
I am using Joomla 3.6.5 running on PHP 7.0.14.
More
8 years 5 months ago - 8 years 5 months ago #875 by joomlate
Hello is it possible to acces your backend and see it?
Last edit: 8 years 5 months ago by joomlate.
Time to create page: 0.213 seconds
