Impossible to find the right settings
More
12 years 2 months ago #159 by leanman
My objective is the have the module located to the right of the page.
After trying different options I get the following result which can be seen at the following address : www.net-factory.fr/a-propos
- the module is correctly located on the right and unfolds as expected
- it is supposed to display the same "Contact" form module as the one that can be seen at the bottom of the home page (ww.net-factory.fr) but it is empty
- also the title of the module (Sidepanel_JT1 Module) is displaid at the bottom of the page. I can't find a way to remove this module title
The settings that I retained can be seen in the attached files.
Thank you in advance for your assistance.
  • admin
  • Visitor
  • Visitor
12 years 2 months ago #160 by admin
Replied by admin on topic Impossible to find the right settings
send me backend acces by private message I will set it up for you.
  • admin
  • Visitor
  • Visitor
12 years 2 months ago #177 by admin
I ve checked it out it seems like jquery conflict but I could not fix it. Try a different template and see if the problem persists
Time to create page: 0.223 seconds
