Slide out panel is displayed while page is loading.
More
5 years 8 months ago #1104 by ncaipen@enetohio.com
I am using SlidePanel JT1 on three different sites, and on all three you are able to see the panel on the page before the page fully loads. It is very quick, but my client is complaining. Can anything be done about this? Here are the example sites:
www.gchmachinery.com/
www.gchtool.com/
www.ohiotoolworks.com/
Thank you in advance for any assistance you can give.
More
5 years 8 months ago #1105 by joomlate
Hello
Thanks for choosing my module. In my opinion the page is loading slowly but module is fast.You have The problem with your website load time I think. Something should be done for it. Regards
More
5 years 8 months ago #1106 by ncaipen@enetohio.com
I ran a speed test and the sites get A/B (both green) grades for speed. I tried to attach a screenshot to show the results but your attachment function isn't working. Is there anything else that can be done to correct this loading issue?
More
5 years 8 months ago #1107 by joomlate
Does the loading time improve when disabled SidePanel?
More
5 years 6 months ago #1117 by IDEM
how to install a "setTimeout (mafunction, 5000);" to delay the opening of the panel?
I do not know the programming, can you tell me how and where to add this code?
thank you
More
5 years 6 months ago - 5 years 6 months ago #1118 by joomlate
Hello Sidepanel Uses TabslideOut Jquery script. In Js/Sidepanel.js line 360 there seems a code setting that feature.
if (settings.onLoadSlideOut) {
open();
setTimeout(open, 500);
But increasing timeout does not make any change. Maybe some javascript help
is needed. You can seek support on javascript forums.
Last edit: 5 years 6 months ago by joomlate.
Time to create page: 0.239 seconds
