Module Columnist JT1 Joomla 2.5 - Error
Error --> modules/mod_columnist_jt1/tmpl/static.php on line 32
Can you help?
I copy a few lines of LOGS
[Fri Sep 20 20:21:37 2013] [warn] [client xx.xxx.xx.xxx] mod_fcgid: stderr: PHP Notice: Undefined variable: titlecolor in /var/www/vhosts/midomain.com/httpdocs/modules/mod_columnist_jt1/tmpl/static.php on line 22
[Fri Sep 20 20:21:37 2013] [warn] [client xx.xxx.xx.xxx] mod_fcgid: stderr: PHP Notice: Undefined variable: titlecolor in /var/www/vhosts/midomain.com/httpdocs/modules/mod_columnist_jt1/tmpl/static.php on line 32
find that code at the top of the file
defined('_JEXEC') or die('Restricted access');
and add that code just below it
$titlecolor=$params->get('titlecolor');
thanks for reporting that bug.
